LT-1 sounds like a farm truck
Old Jul 13, 2005 | 09:25 PM
stephenspann27's Avatar
My car sounds like a damn farm truck when I crank it, and untill it gets to temperature.. My car had a vavle job 20k miles ago, Lt-4 vavle springs, and a mild comp cam. I've tightend the valves several times with the car running.. afraid to get them much tighter. any ideas?
__________________
Old Jul 13, 2005 | 09:44 PM
fade2blk500's Avatar
Re: LT-1 sounds like a farm truck
I take it you are trying to say it has excessive valve train noise? You've replaced everything but lifters it looks like. You might also want to check for exhaust leaks, they can sometimes be masked as valvetrain noise.
Old Jul 13, 2005 | 09:47 PM
I'm sorry, I have new lifters too, I'm pretty sure it's valve trian noise, I've used stethiscope (spelling?) I'm going to be installing my headers soon. I guess I will find out for sure if it's exhuast leaks then.
Old Jul 15, 2005 | 05:37 AM
Are you using stock rockers? Roller rockers are known for a little more noise. How are you adjusting the valves?
Old Jul 15, 2005 | 01:04 PM
yea stock rockers, I"m adjusting them with the car running. First I use a stethiscope to figure out which ones seem to be making the most noise. I turn the nut 1/4 to a 1/2 turn, I'm scare to over tighten.. And yes I know the best way to adjust them is with a feeler gauge and the car off.. but that's time consuming. I did that when I first put the motor back together.
Old Jul 15, 2005 | 01:59 PM
FIREHAWK #7's Avatar
got a set of roller rockers for sale.... comp cam magnums.... give me a PM if you want em....
Old Jul 15, 2005 | 03:36 PM
luckyou03's Avatar
I had alot of valve traing noise before I rebuilt my motor and after new lifters, rods, springs, cam, complete valve job. It's the same.
Old Jul 16, 2005 | 03:46 AM
glad to see I'm not alone
Old Jul 20, 2005 | 02:05 PM
When I was taking my stock manifolds off to put on my headers, the back bolts on both sides were only finger tight, and I could see where the exhuast had been leaking. After installing headers alot of the noise went away, and now I can better hear what is vavle noise, and it seems to be mainly one valve that is making most of it. So I will just tighten it.
Old Jul 20, 2005 | 03:49 PM
luckyou03's Avatar
yes a exhaust leak ticking is like 10x louder than any valve train noise.
GT what?
Jul 14, 2015 10:17 PM
asilomar244
Jul 12, 2015 05:53 AM
Jul 10, 2015 02:23 PM
surreybrad
Jul 5, 2015 10:36 PM
