LT-1 removal
Old Mar 30, 2003 | 12:53 PM
  #16
lt1camaroman93's Avatar
Its simple to pull it out the top. Best way is to buy a happy hooker from tpis as stated before, it bolts to the intake mainfold where the fuel rail bolts down and has a hook on it to pull the engine with. Undo the wiring harness. drop the trans, take out the radiator, i dont have ac so im not sure if you would have to pull the condesor or whatever its called. Take off the accesory's and braket, and water pump. i can get mine out in about an hour and a half to two hours.
Old Mar 30, 2003 | 04:18 PM
  #17
notstock4long's Avatar
So the happy hooker actually bolts to the manifold? I figured you would have to take the manifold off first, then it would bolt on.
Old Mar 30, 2003 | 05:18 PM
  #18
yep.. take fuel rail off and bolt the happy hooker on.
Old Mar 30, 2003 | 05:58 PM
  #19
RCF925's Avatar
While were on the subject I pulled my last lT1 out with the tranny, But that that was on a wrecked car after I sawed off the front. Can you pull just the motor out the top without removing the tranny (M6)?
DarksideII
Parts Wanted
Sep 23, 2015 11:14 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
4586
Jul 31, 2015 06:03 PM
1995Blackz28
Jul 20, 2015 09:34 AM
