LS7 Lifter Question!!
Old Mar 30, 2008 | 05:19 PM
19z28camaro02's Avatar
Question LS7 Lifter Question!!
Are they a replacement for the LT1 lifters? Does any maching have to be done to put LS7 lifters in the LT1 heads?
Old Mar 30, 2008 | 05:27 PM
dangalla's Avatar
no machining but it would be a good idea to check your pushrod length
Old Mar 30, 2008 | 06:30 PM
94zgreenmachine's Avatar
I have a bad comp r lifter. I also have some new LS7 lifters to replace the comp r lifters. I plan on measuring the depth of the pushrod cup to determine if there is a difference. I have seen the posts/arguing on here so maybe we can put this to rest with an answer.
Old Mar 30, 2008 | 06:32 PM
sounds good
Old Mar 30, 2008 | 06:42 PM
dangalla's Avatar
that would be great i would love to know for sure, like i have said in the past i did not measure the difference but i can tell you they visually "look" different in the cup area, otherwise they are exactly the same. i usually just tell people to measure just to be sure although i believe the difference, if any, will not be large enough to require a difference in pushrod length
Old Apr 5, 2008 | 05:00 PM
ssean92's Avatar
I have a set on ebay for sale it you are looking
Old Apr 6, 2008 | 01:35 AM
1963SS's Avatar
LS7 lifters?? Aren't these the ones that let the new Vette rev to 7200-7500 or something like that?? I'll give you a hundred for them.
Old Apr 6, 2008 | 07:28 AM
meaning?
Old Apr 6, 2008 | 12:31 PM
dangalla's Avatar
new from the dealer they cost 100, do your homework before you buy,
Old Apr 6, 2008 | 12:43 PM
OneFlyn95z28's Avatar
I have a ton of lifters. Most all of the made. Maybe later I will measure a few.
i CAN tell you that early LS1s used LT1 lifter and then they changed and the cup IS in fact different.
I will check later
Old Apr 6, 2008 | 01:59 PM
ssean92's Avatar
I will check later
120 from summit ant 100-130 at dealer depends were you are.....and yes they are diff in the cup size
Old Apr 6, 2008 | 08:43 PM
C_Rules's Avatar
can your current springs handle the extra lift?
Old Apr 6, 2008 | 08:52 PM
dangalla's Avatar
extra lift from what?
DirtyDaveW
Mar 15, 2015 07:01 PM
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Jan 18, 2015 08:08 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
