Ls1 roller lifters in a LT1 ???
Old Jan 27, 2007 | 03:53 PM
hogs's Avatar
CAn you install LS1 roller lifters into a 1995 lt1 engine with out any plms. and will all fit as stock?
also what are the advantages in doing so? Thanks Guys??
Old Jan 27, 2007 | 04:20 PM
RE AND CHERYL's Avatar
They are different
Old Jan 27, 2007 | 04:40 PM
Most places sell replacement LS1 and LT1 lifters as the same, from what I have seen.
Old Jan 27, 2007 | 04:55 PM
IrocSS85's Avatar
they look identical to me. I bought some LT1 used lifters to modify to make solids for mockup/clearance testing and whatnot, and they look identical.
Old Jan 27, 2007 | 05:07 PM
Dave89IROC's Avatar
the lifters are the same, the plates are different, but the lifters themselves are the same
Old Jan 27, 2007 | 05:08 PM
speed_demon24's Avatar
They are the same, I'm running a set of the gm race lifters in my car.
Old Jan 27, 2007 | 05:22 PM
hogs's Avatar
What do you mean the paltes are different?? For what I`m getting here they are the same dia. and height both being OEM so they should be a direct fit??
Old Jan 27, 2007 | 05:37 PM
Dave89IROC's Avatar
the plates that hold them in place in the block, not any part of the lifters, the lifters are the same
Old Jan 27, 2007 | 05:42 PM
rskrause's Avatar
Moderator
One of the few things to carry over to Gen III was the lifter diameter.
Rich
Old Jan 27, 2007 | 06:41 PM
AdioSS's Avatar
West South Central Moderator
Rich
That still surprises me that they didn't increase the diameter.
Old Jan 27, 2007 | 06:47 PM
Dave89IROC's Avatar
even the current gen 1 crate engines use the newer design LS1 lifters
Old Jan 27, 2007 | 07:22 PM
hogs's Avatar
DAve89IROC,
How are the p[lates different, Where could I see some pictures of them, and if the lifters are all the same so then should not the LS1 lifters be able to be held in with the stock LT1 plates then, or do ya mean just that the LS1 plates are better quality for some reason, But either plates will work to hold them in Correct??
Old Jan 27, 2007 | 08:31 PM
IrocSS85's Avatar
the lifters are the same. just reuse your lifter spider (retainer). the LS1's use a totally diff. way of keeping the lifter in place and not rotating. dont worry about it. scoggin dickey has great deals on LS7 lifters Ive hears, also there's a perf. lifter thats made for the cadilac cts-v. not sure which ones the best price though.
Old Jan 27, 2007 | 08:45 PM
rskrause's Avatar
Moderator
I was surprised at that too. Probably has to do with production machinery - like the 4.40" bore center which also carried over.
Rich
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
Jazsun
Dec 29, 2014 12:14 PM
siguy
Nov 27, 2014 10:07 AM
