LS1 brake swap?
Old Mar 13, 2004 | 01:49 PM
Mr.Whitey's Avatar
LS1 brake swap?
For those that have done this already, did you use the LT1, LS1 or Earl lines? If you're using the LT1, do you have any pics of what needed to be "adjusted" to make it work? I want to make the needed adjustments before I powder coat everything. If you're using the Earl's, what pn are you using?
Old Mar 13, 2004 | 02:01 PM
twdz28's Avatar
I just used the stock lines. I bent the hard lines coming off the calipers a little so their where no problems with kinking.
Old Mar 13, 2004 | 03:14 PM
steve-d's Avatar
Used the LS1 lines. Worked well.
steve
Old Mar 13, 2004 | 04:08 PM
1msfyter's Avatar
Just finished mine today. I bent the stock plate down to attach the LS1 brake line and use zip ties to keep it from moving. Piece of cake. No rubbing or kinking.
Old Mar 14, 2004 | 12:39 AM
JJ's95B4C's Avatar
I did the same exact thing over a year ago when i first did the swap, and haven't had a problem since.
Old Mar 15, 2004 | 10:20 AM
LT4Firehawk's Avatar
Bend down the mounting tabs and use the LT1 lines.
Old Mar 15, 2004 | 11:43 AM
Don 97 SS's Avatar
Ditt, that is what I did and it has worked fine for three years.
HarleyZ28
Oct 5, 2015 06:23 AM
Zee man
Feb 12, 2015 07:07 AM
ddr698
Jan 9, 2015 10:05 AM
Jul 4, 2005 05:00 PM
