LS1 brake swap?
LS1 brake swap?
For those that have done this already, did you use the LT1, LS1 or Earl lines? If you're using the LT1, do you have any pics of what needed to be "adjusted" to make it work? I want to make the needed adjustments before I powder coat everything. If you're using the Earl's, what pn are you using?
Originally posted by 1msfyter
Just finished mine today. I bent the stock plate down to attach the LS1 brake line and use zip ties to keep it from moving. Piece of cake. No rubbing or kinking.
Jul 4, 2005 05:00 PM
