LS! MAF on an LT1?
Old Jul 28, 2003 | 03:43 PM
TexasTechTA's Avatar
LS! MAF on an LT1?
I am running lean and someone suggested putting an ls1 maf on my 96 lt1 it will make it run ricjer wehat doy uo guys think?
Old Jul 28, 2003 | 08:26 PM
97FormulaWS-6's Avatar
nope...
get yout PCM programmed to remove some of the lean condition.. or figure out what's causing it and fix it.
Old Jul 28, 2003 | 08:43 PM
91RSLT1's Avatar
I am also curious as to if the LS1 MAF will work on the LT1 . I have a 2002 MAF that does not have the screen removed or ported like my stocker. I wanted to put the 2002 on my LT1 because it is untouched. If it does not work then I will just swap internals between the MAF. I just thought it would be nice to have a back up.
Old Jul 28, 2003 | 09:53 PM
if it is a '02 85mm Z06 MAF then it will work with the correct pigtail and your PCM programmed for it, e-mail me if you need the MAF Freq/Flow Table.
Old May 29, 2004 | 05:31 PM
Highlander's Avatar
What do you mean with the correct pigtail?
Old May 29, 2004 | 06:13 PM
madwolf's Avatar
Nick,
did you dyno it and it was lean on the graph?
If you switch to a stock MAF, it will be fine.
DirtyDaveW
Dec 1, 2016 05:37 PM
4586
Dec 31, 2014 02:21 PM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
