Lowering fuel pressure
Old Jul 12, 2003 | 07:42 PM
Koby's Avatar
Is there anyway to cheaply lower the fuel pressure? I know with an AFPR it will temporarily. Once the PCM notices the BLM's higher than 128 it will add fuel, so this makes the AFPR kinda useless. So without touching the PCM can it be done, or do you have to modify the PE vs. RPM tables to actually get lower pressure?
Thanks.
Old Jul 13, 2003 | 07:24 AM
slopokrodrigez's Avatar
The PCM can't change fuel pressure. It can change the pulse width to the injectors. The fuel pump is either on or off and the FPR is governed by vacuum. Tru, if the PCM sees a lean condition, it can change the pulse width to bring it back to stoicky. What are you trying to accomplish? Do you think you're running rich? Unless your fuel pressure is unusually high, its not cause of pressure.
Old Jul 13, 2003 | 08:53 AM
rskrause's Avatar
Moderator
Same question: what are you trying to accomplish?
Rich Krause
Old Jul 16, 2003 | 09:41 PM
Koby's Avatar
I am trying to find a way to lower my preasure and not have the pcm make any adjustments to keep the fuel settings stock. According to my Air/Fuel gauge i am running kinda rich. I beleive my 85MM MAF caused this problem but I don't still have my stocker so I can't tell. Would a MAF Translator work??
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
