lower radiator hose
lower radiator hose
hey everybody just wanted to ask this,it might sound stupid,but any help or info is appreciated,everything was perfect on my car,running wise,cooling etc. my lower radiator came off after i dropped off my wife to work, when i got home.but what i didnt understand was that why didnt the hose come off when i was driving her on the way there, and before i been driving the car i never had any hoses come off, so after the hose came off i waited for the car to get cold,when it cooled off i attached the hose back on i tighten the clamp till it squeezed to the hose,put coolant in and opened the bleeder screws to burp the air out. then i ran the car at running temp like the middle of the gauge, i turned off the car then in a few minutes ka poosh the hose came off again. now can anyone explain this, how are everyone elses 93-97 LT1 camaros lower radiator hose doing
Re: lower radiator hose
I agree, that the hose likely needs to be replaced. If it's sliding off, even after being tightened down, the hose is no good. You should be able to tell that by looking at it when it's off (inside and out).
back to square 1 again fellas!!! is it possible to get pics of anyones 93-97 LT1 camaro/firebird the lower radiator hose.
im having the problem of it sliding off the radiator,i havent checked in in like a couple months but yesterday i checked it and it wasnt as bad as i thot,it was about less than a half an inch from the stem,so basically id like to see pics of how the lower radiator hose attached.
I know it sounds dumb but i need to get this issue straighten out before i destroy this car cuz its pissing me off
thank u guys
thank u guys
Check to make sure the plastic nipple on the radiator isn't cracked. If it is, tightening down the clamp will just spread the plastic, leak, and it won't hold.
You really shouldn't need a picture. It's just a hose nipple and a spring clamp.
cool thank u Joe i have been keeping my eye on the hose i havent seen any leaks coming from the hose and no signs of it coming off,ill just keep a look on it and if does it again ill take a look at the nipple/stem.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Critter
Apr 23, 2015 09:38 PM
ro2207
Dec 4, 2014 06:18 PM
