Low voltage in the rain?
Old Jun 22, 2004 | 09:28 AM
gamecockfan04's Avatar
I had to drive home yesterday in the rain and with my wipers,lights,radio,and AC on my voltage was dropping to the middle of the yellow area. However when I turn the AC off it goes back up slightly to the beginning of the yellow area.Is this anything to be concerned with? because it scares me sometimes, thinking that Im going to stall, or something. I also noticed that my battery is not the correct one I need, because its only like 600CCA, but this sounds more like an altenator problem to me.
Old Jun 22, 2004 | 09:47 PM
ChickenScreamer94's Avatar
Try cleaning the ground lug on the pass. side of the strut tower. It has three major negative cables (black) running to it. Remove it and clean it thoroughly until the metal is clean and reassemble.
Old Jun 22, 2004 | 10:19 PM
ru2slo_99's Avatar
If it just happens in the rain your belt might be slipping. My car does that every morning when I drive through the water puddle in the parking lot of my apartment.
Old Jun 22, 2004 | 10:27 PM
stonez96z28's Avatar
check your connections. get your battery tested. if your battery is good, check the output of your alternator.
meissen
Aug 11, 2015 06:05 AM
Boss002
Jul 24, 2015 10:47 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
Jul 10, 2015 02:23 PM
Boss002
Jul 9, 2015 03:33 PM
