Low Voltage problem 97 Camaro LT1
Old Jun 10, 2012 | 11:50 AM
77 Formula's Avatar
Angry Low Voltage problem 97 Camaro LT1
Like the title says I have been fighting this for a few weeks now I have checked the alt. checked all my grounds and cleaned that I could find even added a ground and still have a LOW VOLTAGE problem what else can it be
Old Jun 10, 2012 | 01:01 PM
Re: Low Voltage problem 97 Camaro LT1
Give some more detail with numbers.
Old Jun 10, 2012 | 01:20 PM
77 Formula's Avatar
At idle it will hold 14 volts but when put in gear it drops to 11 volts it also has an under drive pulley on it also when it's first started the volts climb really slow
Old Jun 10, 2012 | 01:31 PM
Dave89IROC's Avatar
Take the underdrive pulley off
Old Jun 10, 2012 | 04:03 PM
The alt won't charge much under a certain RPM. The pulley may be spinning the alt too slow.
Old Jun 10, 2012 | 08:20 PM
77 Formula's Avatar
That's what it was THANKS for the input
Old Jun 11, 2012 | 04:36 PM
77 Formula's Avatar
How do I get the lights off now that I have my voltage back they are the low oil,check gages, and abs inop lights
Red Hawk 94
Mar 18, 2019 04:03 PM
pete53
Dec 9, 2014 07:31 AM
siguy
Nov 27, 2014 10:07 AM
Eric H
Aug 10, 2002 06:39 AM
Rino1313
Jul 18, 2002 05:16 PM
