Low RPM stumble after cam install
Old Jul 25, 2004 | 02:41 PM
818camaro95's Avatar
Thumbs down Low RPM stumble after cam install
I had a cam installed and now I have a low RMP stumble. I checked the wires to the opti they are routed correctly with no burns, I re-gaped the ngk plugs, replaced the coil. I'm using Madwolf's programming. It's not throwing any codes, what do you think it is?
Old Jul 25, 2004 | 05:07 PM
slopokrodrigez's Avatar
Re: Low RPM stumble after cam install
Tps maybe?
Old Jul 25, 2004 | 06:04 PM
What does the tps cost? I forgot to mention If I don't let my car warm up for a couple minutes it will die as soon as I put it in drive.
Old Jul 26, 2004 | 08:59 AM
Old Jul 26, 2004 | 09:35 AM
MetallicTrans96's Avatar
That big cam sitting there loping
Old Sep 16, 2004 | 06:37 PM
blown383's Avatar
Any updates?
-B
Old Sep 16, 2004 | 07:23 PM
LT1WanaBe's Avatar
Time for a 3000 Vigilante
Old Sep 16, 2004 | 07:32 PM
Cmr0z28's Avatar
What kind of cam?
Old Sep 16, 2004 | 08:43 PM
speed_demon24's Avatar
Its called lope...
Old Sep 16, 2004 | 08:47 PM
Spinner's Avatar
Get used to it
Old Sep 16, 2004 | 09:07 PM
turbo_Z's Avatar
Did you also upgrade to 30lb SVO injectors at the same time? If you did that might be causing the problem. Mine when cold definitely have a low rpm type stumble that goes away after a few mintues of warming up.
Old Sep 16, 2004 | 09:13 PM
It's a spun bearing I'm selling the car to my friend, he can deal with the piece of crap
Old Sep 16, 2004 | 09:47 PM
blown383's Avatar
How did they diagnose the spun bearing?
-B
Old Sep 17, 2004 | 02:36 AM
ZeeDub's Avatar
sounds like cam lope to me... is the car running fine at higher revs? try and tune your idle (if at all possible) to about 1200 RPMs, see if that does it... where is it stumbling?
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
GigaMp3z
Feb 20, 2003 02:57 PM
