low rpm miss under load?
Old Oct 18, 2003 | 12:41 PM
cat1055man's Avatar
My 1994 LT1 has developed a miss under 2000 rpm under heavy load. Above 2000 rpm at full throttle it runs strong with no sign of a miss. I suspect carbon traces in the optispark.When it miss fires under laod there is an occasional ping and the car bucks. Has any one experianced this type of failure mode of an optispark or other suggestions of what I should check before I pull the water pump and lay out big $$ to replace this poorly designed piece of crap?
Old Oct 18, 2003 | 01:47 PM
96z's Avatar
96z
Before you go out and spend some big money check the plugs, wires, coil, and coil wire. The coil and coil wire usually are bad with a high RPM miss but it wouldnt be bad to check those out. Do you have any codes?
Old Oct 18, 2003 | 02:01 PM
NVetro's Avatar
Honestly, my low rpm sputter was caused by a dirty MAF and a dying fuel pump. Test your fuel presure. Also replacing coil, wires,plugs can help also. You will uslly get an SES light if you have a misfire, I thought it was my opti when I had my low rpm sputter but it wasn't and I replaced mine.
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
