low revs=low oil pressure. what gives?
Ok fellows-I sure hope that some of you can help me out with this one. Car doesn't burn a drop of oil, but at idle and low revs, it reads at the quarter slash mark, but when I rev it up, it goes up to exactly the mid mark-which is where it sits when I'm cruising (at 2000 revs or higher). Any thoughts? I just changed my oil (mobil 1) so I know its not a clogged filter.
The oilpump will increase pressure as it comes up in RPM, Alot of people have reported lower oilpressure after switching to synthetic oils. As long as its 15 to 20 at idle (no lower than 10 at the very least) you'll be ok. You did say that it comes up to the 40 or so mark when you are on the gas right?
guionM
14
Jun 19, 2002 08:30 AM
