low oil presure
Old Jun 8, 2003 | 06:37 PM
johncruz's Avatar
low oil presure
why do I have low oil presure with only 35000km on my engine?
Old Jun 9, 2003 | 12:05 AM
fbird95's Avatar
Could be the gauge or the sending unit for the gauge. Most likly the sending unit. these gauges arnt exactly the most precise instruments. They were put in more as a novelty. All across the board you will hear different readings at diffrent rpms.
Old Jun 9, 2003 | 11:16 AM
johncruz's Avatar
Thanks fbird 95. I had the oil pressure manually tested and it was 6psi at warm idle which really scares me when the check gauges light comes on cause then it must be below 6psi then which is not good. I just can't beleive it. Never raced her or drove it hard, can't figure why this happening to my car with low milage. Makes me wonder whats next.
Old Jun 9, 2003 | 12:15 PM
My95Z's Avatar
mine is pretty low to, at wrm idle it is probably little under 20, but then it goes up with the more rpm..but I don't know iof it goes up high enough
Old Jun 9, 2003 | 12:17 PM
JasonK94Z's Avatar
Using a Fram filter? I found a fram filter will lower my oil pressure, and an AC Delco filter will not.
Old Jun 9, 2003 | 12:19 PM
johncruz's Avatar
does your check gauges light come on? If it does then your having the same problem as me. Now figuring out what's causing it I don't know
Old Jun 9, 2003 | 12:50 PM
My95Z's Avatar
my light doesn't come on and I do use fram
HectorM52
Jul 30, 2017 11:46 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
carl.froehlich
Mar 13, 2015 12:38 AM
siguy
Nov 27, 2014 10:07 AM
