Sealant on Head Gasket?
Old Jun 9, 2003 | 07:21 AM
94_Z28_guy's Avatar
Question Sealant on Head Gasket?
Getting ready to put my heads back on....
Looking at the stock gm gasket set I took off, looks like there is thread sealant ON the gasket around some of the holes (light yellow in color, about 1/4 inch around holes).
Should I put sealant around the same holes with the new gaskets, or just put them on? Haven't read or seen anything about doing that.
Thanks.
Old Jun 9, 2003 | 10:15 AM
slashz28's Avatar
nope. only the gasket, no sealant. im not a pro, and only did it once, but i didnt use any sealant on them . hth
Old Jun 9, 2003 | 11:16 AM
Mr. Z28 73/97's Avatar
You need to get some ARP Thread Sealant to put on your head bolt or stud threads, that is what you see on your old gasket.
You have to do this because most of the bolts/studs go directly into the water jacket and if you donn't seal them water can leak past them and you'll soon be changing heads gaskets or worse(totally rebuilding engine if water and oil mix and u ruin the bearings).
Old Jun 9, 2003 | 11:42 AM
slashz28's Avatar
the bolts i bought had sealant already on them. but this guys right
Old Jun 9, 2003 | 12:53 PM
94_Z28_guy's Avatar
Okay.
I have the bolts, and they have sealant on them, but no where near enough to squeeze out the hole and get onto the gasket when you tighten it down.
As long as the consensus is no sealant needs to be added to any area on the gasket itself, I will not use any.
Thanks.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
