Low Oil Pressure
Old Mar 2, 2003 | 08:13 PM
96Z28man's Avatar
Low Oil Pressure
I recently did my LT4 HOTCAM swap. Today I noticed my oil pressure was real low, like maybe at 20 or lower. But there is no knocking sound coming from the engine. What else could be causing low pressure?? How low is too low??
Old Mar 2, 2003 | 08:20 PM
94z28jbw's Avatar
Question
Was that the pressure right after you started it up? Or after it had warmed-up? Also, didn't your pressure rise w/ your RPM's?
Old Mar 2, 2003 | 08:29 PM
96Z28man's Avatar
yes, pressure kinda rises with the rpms, then just slowly lowers. When I start it up, its good. As I drive, it gradually gets worse. What is causing this???
Old Mar 2, 2003 | 08:32 PM
$hawn's Avatar
Sounds normal to me, once the oil warms up it gets thinner and the pressure will be lower, but you make it seems like it's just done this recently.
Old Mar 2, 2003 | 08:35 PM
94z28jbw's Avatar
Thumbs up
Well, your pressure is supposed to stay way up while it's warming up....then it's supposed to climb with your RPM, and also drop with your RPM. Your oil-pump is mechanical, I have heard other people that have problems after installing a new cam....I think it may be due to a lower vacuum in the crankcase....not sure.....I bet Shoebox could help you out though......Worst case senario.....look into a Melling Oil Pump; but I bet there's something else cheaper and easier that can be done.
Old Mar 2, 2003 | 10:43 PM
96Z28man:
I tried to reply to your "private message" regarding the problem with oil pressure, but the system indicates it can not send my message because your mailbox is full. You need to delete old messages, since there is a limit on how many can be saved.
As far as the oil pressure, if you are saying there was a radical change in the oil pressure in your engine, both hot and cold, after the cam change, it appears that oil is somehow bypassing the system. I don't know enough about the specific path the oil takes through the engine, but it sounds like the cam bearing clearance might be too large, allowing oil to leak out of the system at that point, and reducing the pressure.
There is also a possibility you damaged the oil pump drive.
It might help if you post actual before and after oil pressure numbers for hot and cold operation. Otherwise, its hard for people to really understand the magnitude of the problem.
Fred/Injuneer
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
