Low oil pressure???
Old Jan 3, 2006 | 07:19 PM
RedsTA's Avatar
Low oil pressure???
So Ive had the car over a year now, and just recently instead of being about 50 when i start it, its now just over 40 psi. After warming up, at idle, the oil pressure is below 20, probably close to 15. While driving warmed, its 30-40psi.
I keep reading cars for sale and other peoples cars who idle at 50 psi and im just wondering if my car is messed up somewhere.
Am I wrong about what the oil pressure should be? Anything i can do to boost the pressure up a little more?
My car just turned over 100k miles:
Hooker LT headers, full exhaust, P&P TB, TB bypass, K&N CAI, Granetelli MAF, Airfoil, MSD 6al. coil. and wires, NGK plugs.
I think thats all that ive done to my cars engine. Any help is appreciated.
Old Jan 3, 2006 | 07:24 PM
RICEFEDZ28's Avatar
Re: Low oil pressure???
The minimum pressure you can have is 6psi for every 1k rpm. As long as your above that don't worry too much. 100k on a motor may just be wear. As long as your not hearing any tapping you should be fine.
Old Jan 3, 2006 | 07:32 PM
RedsTA's Avatar
I heard 10 psi is what you should have for every 1000 rpm. But yeah, im above 6 all the time so thats good. I dont really hear any tapping except when i lift the hood you can hear a slight tapping, i always thought it was the roller rockers since it got louder when i got closer to the valve covers.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
