Low Oil Light on...no oil leak
Old Aug 12, 2003 | 12:27 PM
ryan75's Avatar
Question Low Oil Light on...no oil leak
How can I fix this? The oil is not low, but sometimes when I start my car, the low oil light doesn't go out.
Old Aug 12, 2003 | 12:58 PM
InjectedSS's Avatar
replace the sensor! more than likely its broke! ugh just pray yours didnt break like mine did mine broke into pieces and i ended up having to remove my oil pan to get all the broken pieces out
Old Aug 13, 2003 | 12:04 PM
ryan75's Avatar
wHERE EXACTLY IS IT LOCATED AND HOW TO I GET TO IT TO REPLACE IT? CAN YOU BUY THEM AT O'REILLY OR AUTOZONE?
Old Aug 13, 2003 | 12:09 PM
viperkiller's Avatar
in the oil pan right above the drain plug
make sure to buy the new one first
94ZGRNMCHN's Avatar
Ditto on the sensor
Old Aug 13, 2003 | 12:16 PM
raceryan's Avatar
How do you pull the darn oil pan off without taking the engine out or up?? Can't get to all the bolt's cause of crap in the way. If I did get all the bolts out, I can't pull the pan out.
Old Aug 13, 2003 | 01:19 PM
IDOXLR8's Avatar
Why are you trying to remove the oil pan?? When I removed my oil pan I jacked the front of the motor up and unbolted the motor mounts. That should give you enough room to get the oil pan out.
artic94
Jan 17, 2015 11:19 AM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
