LOW IDLE!! Please Help
Old Mar 25, 2004 | 05:19 PM
OnefstCamaroZ28's Avatar
Banned FOR SCAMMING - Nick[William] Dascal - (516) 931-0586
I was warming up my car today and it was idling very low, it was at 500 rpms, and then i thought it was just cause it was cold but then like 10 minutes later of driving, it idles down to 500-600 rpms. Is that like too low?
Old Mar 25, 2004 | 06:07 PM
FastZinTennessee's Avatar
When you first start the car up, do the RPMs spike up then come down to 500-600 within seconds or when you start the car does it immediately go to 500-600? If it immediately idles low after starting it I'd say you need to start by cleaning your idle air control valve. Might just take the throttle body off and thoroughly clean it.
Old Mar 25, 2004 | 06:43 PM
No it goes up to like 1100 then stays at 900 for like a minute then starts to get down to 600 and 500
Old Mar 25, 2004 | 07:34 PM
My95Z's Avatar
Yep!!
hows it going man, haven't talked to you in a while!
Old Mar 25, 2004 | 09:04 PM
Well if the RPMs go up then come down I really don't know what to tell you. Normal idle should be around 650 in gear. Might run some fuel system cleaner through the system.
Originally posted by My95Z
Yep!!
Going ok, broke the camaro again but that's another discussion
Old Mar 25, 2004 | 09:08 PM
kaoshen's Avatar
What exactly do you clean the Idle air control valve with? Regular soap and water?
Old Mar 26, 2004 | 08:12 AM
I used throttle body spray cleaner on mine, it's in an aerosol can and you can find it at a local autoparts store.
Old Mar 26, 2004 | 01:27 PM
Stock idle speed programed in the PCM for an A4 is 650rpm in neutral and 550rpm in drive.
Old Mar 26, 2004 | 01:31 PM
95Zdroptop's Avatar
Also check you intake elbow and make sure it is not ripped and getting more or less air after the sensor. Most tears are right before the throttle body.
Old Mar 26, 2004 | 02:29 PM
Russtebo's Avatar
On that subject... The rubber slip collar from my K&N cai to the MAF is messed up. Anyone know where I can get just that rubber piece?
FYI, My car does that same thing, running down into the 500rpm range even after it warms up. I will try the recommended cleaning and let you know.
Old Mar 26, 2004 | 05:42 PM
Also keep in mind that your tachometer may be off. Stock GM tachs are not a model of precision, mine read 200 RPM high
andrewcapps82
May 19, 2015 10:11 PM
Noenav
Apr 30, 2015 01:06 PM
edman
Mar 13, 2015 09:39 PM
camy 1993
Feb 3, 2015 06:26 PM
Hot Rod Hawk
Aug 15, 2002 10:47 PM
