Is this a low idle? Help!
Old Aug 9, 2005 | 06:57 AM
ZGOBYBY's Avatar
Hey guys and girls, I just bought a '95 Z w/ 44K on the clock and I noticed what I thought was a low idle in drive. The idle is around 550-600 in drive at a stop. I took my car to a local Chevy dealer and they used a diagnostic machine and they said that's where the idle should be. What do you all think? I still feel that is too low.
Thanks!
Old Aug 9, 2005 | 08:26 AM
anaik's Avatar
Re: Is this a low idle? Help!
Your Chevy dealer is correct. 550 is the idle speed for an A4 in gear, 650 in neutral.
Old Aug 14, 2005 | 11:19 PM
firehawkformula's Avatar
Thanks!
Couldnt figure out how to drive a stick?
Old Aug 15, 2005 | 09:26 AM
2000LS1Z28's Avatar
Exactly what he said...You're A4 is idling just as it should...
Mike
Old Aug 15, 2005 | 09:59 AM
JustNO's Avatar
WHat should be an M6 idle? 900rpm?
Old Aug 15, 2005 | 10:00 AM
madwolf's Avatar
800, but stock tachs may show it as 900-1000.
Old Aug 15, 2005 | 10:05 AM
JustNO's Avatar
thanks its clear now.. Another thing, is a option to raise the idle speed to get smoother idle?
(I don't like rough/lumpy idle ,so can I raise rpm ? Is this unhealthy for engine??)
Old Aug 15, 2005 | 10:12 AM
madwolf's Avatar
You can play with timing for a smoother idle. A higher idle won't hurt the engine, but will probably get annoying.
Old Aug 15, 2005 | 10:36 AM
JustNO's Avatar
My camshaft will give definitaly a rough/lumpy idle..(237/245dur. 113lsa in 383cid) And for my setup I can't go smaller than this, if I get smaller cam it will not worth what I paid for whole engine.. So, to get a smoother dile only way is raise the idle speed I think right?
Old Aug 15, 2005 | 01:58 PM
ScreamnChicken's Avatar
Or get it tuned on a dyno.
What kind of lift does the cam have?
That isn't that big of a cam for a 383.
Where is your idle now?
Old Aug 15, 2005 | 04:21 PM
JustNO's Avatar
lifts 584/579.. I have not an idle my engine is almost built.. But I think my idle will be 900rpm..
Old Aug 15, 2005 | 04:48 PM
jsetzer's Avatar
I have my m6 cc306 idle at 650.
Some say it sounds like ***, some say it sounds nice.
andrewcapps82
May 19, 2015 10:11 PM
Noenav
Apr 30, 2015 01:06 PM
edman
Mar 13, 2015 09:39 PM
camy 1993
Feb 3, 2015 06:26 PM
Hot Rod Hawk
Aug 15, 2002 10:47 PM
