low fuel pressure
Old Jun 8, 2013 | 04:37 PM
  #31
Chet1185's Avatar
Re: low fuel pressure
[autostream]http://autostream.com/camaroz28/?page_type=firebirdplayerthumbnail&framepage=2791& transactionid=1370727423-6913169213&posted_by=Chet1185_www.camaroz28.com&yo utube_video_id=aaKLFMGlp1Y[/autostream]
Old Jun 8, 2013 | 10:33 PM
  #32
slick1hunting's Avatar
I was able to watch it by typing in your user name and looking through your posts. Unfortunately im not the guy whose comment you need. Im guessing you gained a a fair bit given its better by clamping your hose(if it bleed to 0 in 2 seconds vs 8 seconds is a large percentage of leakage stopped) May point me to a pinhole in that line in your tank but I have no idea how quickly a checkvalve bleeds when failed. Or even if somehow the extra pressure from having line clamped would help checkvalve close( no idea how its working in a fuel pump). On my phone your last post did not create a link so not sure if anyone else will be able to watch without typing your user name into search bar as I did(I often have to do that from my phone as most links wont allow me to view for some reason)
Posted from Camaroz28.com App for Android
Old Jun 8, 2013 | 10:39 PM
  #33
Chet1185's Avatar
On the website the video is right there but on our phones it just looks like a bunch of crap. Lol
Old Jun 9, 2013 | 12:46 AM
  #34
ill try and repost your link so perhaps other phone users can link easier if it works. https://www.youtube.com/watch?v=aaKL...e_gdata_player
Old Jul 27, 2013 | 11:11 AM
  #35
Chet1185's Avatar
Finally got it fixed. Bought a used fuel pump assembly and now it hold pressure and starts right up. Still not sure what it is that was wrong because i replaced the whole unit. Level sensor and lines. Everything that you drop into the tank and bolt up.
Sent from my DROID X2 using Tapatalk 2
Old Jul 27, 2013 | 07:05 PM
  #36
97WS6SCharged's Avatar
Likely the flex hose inside the tank was leaking. If you submerge the pump in a 5 gallon bucket of water and apply power/ground you can check it pretty easily.
Old Jul 27, 2013 | 07:48 PM
  #37
Chet1185's Avatar
Would submerging it in the water be good if i fixed the hose and used it sometime down the road?
Old Jul 28, 2013 | 09:57 PM
  #38
It won't hurt the pump to put it in water to test it if that's what you're asking. You may want to spray a little WD40 on the hanger hinge to keep it from rusting if you're going to let it sit for a while though.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Alex Barnes
Jan 24, 2015 10:21 PM
IDOXLR8
Aug 6, 2002 12:30 PM
