Low Coolant Sensor...
Old Jun 12, 2007 | 12:16 AM
Phantomhp's Avatar
What kind of clip(s) hold the low coolant sensor onto the radiator? Can you get these are an autoparts store or only through a dealership?
Mike
Old Jun 12, 2007 | 02:05 AM
blown383's Avatar
I'm not sure... however if you replace it make sure its snaps into place correctly!!!! I only had one side snapped in correctly and it blew off while I was stuck in bumper to bumper traffic....and I basically blew my motor when it over heated.
-B
Old Jun 12, 2007 | 07:31 AM
wrd1972's Avatar
Dealer only, its a funky square clip.
Old Apr 12, 2008 | 08:22 PM
Oxygen454's Avatar
Seems like a lot of people have this low coolent sensor problem as do I. Is it a real PITA to get to and what should I use to clean it with?
Shoebox has an excellent picture of where it is for those who are wondering.
Low coolant sensor
When I do work on anything to do with coolant in truck engines or fuel in fuel tanks, I use a shop vac on the tank opening. Only a couple of drops will drip out when you pull out the sensor making it easy to do and no need to drain out the coolant.
Old Apr 12, 2008 | 09:05 PM
StripedFomula's Avatar
can you explain that shop vac thing a little more?
Old Apr 12, 2008 | 09:27 PM
TRIPOWER's Avatar
the clip should come with a new sensor the pn# is 10096163
Old Apr 12, 2008 | 11:43 PM
94zgreenmachine's Avatar
Originally Posted by Oxygen454
Seems like a lot of people have this low coolent sensor problem as do I. Is it a real PITA to get to and what should I use to clean it with? .
Try removing the battery, it makes acess to the sensor much easier.
Old Apr 13, 2008 | 12:32 AM
LT1 POWR's Avatar
I got mine at O'Reillys for about $45. It is a metal clip that holds it on and yes it is a PITA to get to unless you remove the battery.
Old Apr 13, 2008 | 09:04 AM
Stl94LT1's Avatar
I have a clip you can have? But, it will take a few days to get there.
-Mike
Old Apr 13, 2008 | 01:08 PM
OBE1 95Z28's Avatar
Shoebox has install instructions on this photo: http://shbox.com/1/low_coolant2.jpg
Old Apr 13, 2008 | 06:56 PM
Oxygen454's Avatar
Take a shop vac and a hose preferably 5/8 and attach it to the end of the shop vac hose. I used duct tape. lol Then put the small hose into your rad opening. We use a plastic plug with a hose fitting that we shoved into the middle of a plastic plug. I have used a rag before, works not too bad either.
I was thinking the same thing, remove the batter to get to the sensor. Thanks 94zgreenmachine
Old Apr 13, 2008 | 08:59 PM
caldercay's Avatar
Replaced mine today (coolant level sensor) - it was a breeze. Took the
battery out. Pulled the clip off the sensor. Twisted it slightly (clockwise
and counter-clockwise) - had a short piece of 1/2 hose ready. Then,
pulled the old sensor out and pushed the hose in. I readied the new
sensor, pulled the hose out and inserted the new sensor in. I lost,
maybe, a cup of coolant.
The new sensor came with a new wire clip.
Old Apr 14, 2008 | 12:45 AM
Oxygen454's Avatar
So judging by shoeboxes picture, the clips are pulled straight up?
Old Apr 14, 2008 | 06:48 AM
They are pulled outward from the top and bottom.
Old Apr 19, 2008 | 09:22 PM
Oxygen454's Avatar
What is the best to use to clean the sensor? Just a rag and water or any chemicals?
blac94Z
Feb 15, 2021 09:43 PM
calaban
May 18, 2020 06:43 PM
95z_28_camaro_4_Ivan
28
Jul 23, 2015 11:55 AM
Fatdog2
Apr 27, 2015 10:32 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
