Low Coolant Sensor
Old Jun 22, 2003 | 12:21 PM
RRios8191's Avatar
Low Coolant Sensor
I just bought a low coolant sensor for the radiator at the dealer. $47. Darn it, the light still comes on. Radiator is full. Help??
Any ideas?
95 Z28
5.7L
Old Jun 22, 2003 | 12:38 PM
NiteRider's Avatar
Not sure man, did you install it properly? My sensor went to but I just pulled the dummy light out of the speedo. You can always tell if your low on coolent from your tempreture sensor.
Old Jun 22, 2003 | 12:43 PM
RRios8191's Avatar
Low coolant sensor
Just removed 2 prong harness, removed metal u-clip, replaced with new one, secured clip, plugged harness back in. Even added more coolant. Thing is, there are no leaks and even started car without cap on and saw coolant coming up to top of radiator when car started to warm up. So I know coolant is flowing into sensor.
Old Jun 22, 2003 | 03:11 PM
Re: Low coolant sensor
Originally posted by RRios8191
... Thing is, there are no leaks and even started car without cap on and saw coolant coming up to top of radiator when car started to warm up. ...
If the sensor is not covered with coolant, the light will come on. The radiator should be full to the top. Check it again when it is cool and if it is not to the top, fill it up. Open the bleed screws as you fill to purge any air.
Old Jun 22, 2003 | 03:31 PM
RRios8191's Avatar
Low coolant sensor
Thanks, I'm watching Cubs game and after couple hours will fill all the way to the top!!
Old Jun 22, 2003 | 03:52 PM
Silver's Avatar
Make sure you bleed it.
blac94Z
Feb 15, 2021 09:43 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
91Bird305
Aug 8, 2002 12:36 AM
