LOW COOLANT (not true)
Old May 4, 2005 | 04:17 PM
megladon's Avatar
My low coolant light comes on after it warms up (95 T-A)
I am not loosing water, and the coolant is not low, no water in oil,
no oil in water, Bad sensor maybe????
Old May 4, 2005 | 04:21 PM
Purplemaroz28's Avatar
Re: LOW COOLANT (not true)
having same problem
Old May 4, 2005 | 04:23 PM
LenT1's Avatar
ditto that makes 3 of us, it goes on and off is why I dont think its the sensor so any advice is welcome.
Old May 4, 2005 | 05:07 PM
White Knight 95's Avatar
I had the same problem for a while. Then I wiggled the connector on the coolant level sensor and I have had no more problems. People have also replaced the coolant level sensor for this issue, so search around and I'm sure you will find more suggestions.
Old May 4, 2005 | 06:23 PM
moparman's Avatar
It's a common problem. Lots of people just disconnect the sensor. Just remember to check coolant level every few days.
Old May 4, 2005 | 06:53 PM
WickedLT1's Avatar
Sometimes a small bubble will get attached to the sensor, so it will mis-read. Happens a lot in the older GMs. Usually when this happens, I rap on the radiator tank a little with a screwdriver handle and that gets it loose. This cause would show up right after a coolant flush, or a wp replacement. Anytime you drain the rad and burp the system.
-Paul
Old May 4, 2005 | 08:21 PM
Robs97Z28's Avatar
I had the same trouble with the low coolant light. It ended up being a head gasket.
Old May 4, 2005 | 08:25 PM
ericz28w's Avatar
i just unplugged my sensor, no problems
Old May 4, 2005 | 09:19 PM
Steve0's Avatar
I unplugged my sensor too, no more problems! Just check your coolant levels from time to time.
Old May 4, 2005 | 09:51 PM
motownz's Avatar
I now have the same probem on a 93Z. When I contacted the dealer for a new sensor they informed me that it had been dicontinued in 02.Where do I go to get a new sensor? thanks
Old May 5, 2005 | 12:49 AM
ssbowtie1's Avatar
You could try removing the sensor and cleaning it. Sometimes a bit of buildup gets on the sensor and could cause it to malfunction.
Old May 5, 2005 | 01:17 PM
brians96Z's Avatar
I must be one lucky duck, cause I have never had this problem on mine, and I'm at 114K miles.
Old May 5, 2005 | 01:24 PM
97greentransam's Avatar
I had the same problem on my 97 TA went to autozone and special ordered a new sensor which cost me 70 bucks. drove it home turned the car off came back out to leave and it wasnt on and has never came back on so who knows. Now i have a brand new sensor that i have no use for.
blac94Z
Feb 15, 2021 09:43 PM
calaban
May 18, 2020 06:43 PM
Fatdog2
Apr 27, 2015 10:32 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
