Didn't install poly motor mounts with headers....
Old May 3, 2005 | 11:19 PM
fredmr39's Avatar
I have had no clearance/y-pipe issues currently. So are the stock ones sufficient? What are other real benefits from switching over besides holding the engine better? Is it "bad" necessarily for it to move? Finally, since I didn't do it with the header install and there's no way in hell they're coming off again, is this task possible with LT's on the car? Thanks!
Old May 4, 2005 | 12:00 AM
FIREHAWK #7's Avatar
Re: Didn't install poly motor mounts with headers....
i want to know the same thing..... ever since i put my LT's on, they have been rubbing on the K member; i ordered the poly. motor mounts by PROTHANE and want to know how difficult it is to put them on..... any write ups, tips are welcome.... THANKS
Old May 4, 2005 | 02:20 AM
fredmr39's Avatar
I recall hearing something about removing the alternator (no biggie) and the A/C (no idea how to begin to remove A/C or what parts exactly require removal) to "free up room" -- now, is this to free up room to make the job easier, or is this to make it possible?
I do recall an A/C line PERFECTLY in line when I broke the bolt loose to jack the motor for LT install....
Thanks guys - I'm still curious also about the other advantages/etc I mentioned in initial post!
Old May 4, 2005 | 07:25 AM
teke184's Avatar
polymounts i think make a huge difference. why "anticipate" no clearance problems when you can be 99.9% sure of it with the new mounts.
they are relatively cheap insurance.
and if the LT1 is anyting like my LS1...there is NO WAY IN HELL you are installing them after the headers go in.
it was a 10hour job when i had just manifolds. would have been a 2hr job if i had done it when i put headers on...there is tons of room with the exhaust out of the way
Old May 4, 2005 | 09:21 AM
magnumv8's Avatar
Originally Posted by fredmr39
I have had no clearance/y-pipe issues, and do not anticipate any. So are the stock ones sufficient? What are other real benefits from switching over besides holding the engine better? Is it "bad" necessarily for it to move? Finally, since I didn't do it with the header install and there's no way in hell they're coming off again, is this task possible with LT's on the car? Thanks!
you may not have issues now, but the rubber ones will sag as they age. If you have already installed everything, then just go with it until the stock ones wear out. I just dont like doing the same job more than once, so I replaced them with poly when I had everything apart.
Old May 4, 2005 | 12:23 PM
fredmr39's Avatar
Damn...wish I had known it was such cheap insurance -- I was unaware of the price on these when installing, thought it was a lot more -- but I must have seen something else -- guess I'll just hope these hold up another 5 years or so until I get new headers -- or maybe I'll blow a gasket and that'll force me to want to do it, who knows...
Old May 4, 2005 | 03:27 PM
Type_O_Negative_1320's Avatar
This happened to me...my longtubes went on years ago and I didn't have any clearance issues. As time went on, the stock rubber mounts started to sag and finally reached the point where the headers were resting against the k-member. I had the mounts replaced with Prothane poly mounts when the motor was replaced and all has been well since.
Old May 4, 2005 | 03:48 PM
RedRyder518's Avatar
Just a tip, you will probably have to remove your y-pipe if you want to replace the mounts. I tried to jack up my motor when I attempted to replace my motor mounts with my headers in and the y-pipe would hit against the body not letting me get enough clearence. I gave up because I didn't have the time or patience to take off my Y.
Old May 4, 2005 | 06:03 PM
Like My Taillights?'s Avatar
i was able to change the mounts with AS&M headers on the car. It is a pain, but it can be done. It would be a piece of cake with no manifold or headers in the way though.
Good luck
Don't even worry about this stuff, nothing is in the way except those headers
Old May 5, 2005 | 01:25 PM
*Q#!%$#&* i am in the process of changing them out now..... IT IS A PAIN IN THE ***...... but it can be done.... the hardest part is lineing up the 3 bolts that go into the K member.....
Old May 5, 2005 | 01:33 PM
fredmr39's Avatar
I dropped the K-member in an attempt to make my initial LT install easier.....well, dropped one side loosened the other -- I recall no problems realigning those bolts...
HectorM52
Jul 30, 2017 11:46 AM
Jason Short
Jan 19, 2015 06:34 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
