Low coolant light, worried
Old Sep 4, 2007 | 02:23 PM
Camm95Z28's Avatar
Hello all, recently my low coolant light has been on. I woudl check the coolant level, it would be halfway down the neck of the resevoir. No biggie, probelm solved.
This was Thirsday, today it came on again, the colant level after being filled up, went down maybe a inch. The light does go off once the ignition is restarted, but comes on again a few seconds later once moving. Tempertaure gauge doesn't move, but it does have me concerned cause the RF cooling system and I have had a history.
Is there a problem or just 180,000 miles plus and a goofy sensor wanting to be known? Thanks
Old Sep 4, 2007 | 02:29 PM
Stl94LT1's Avatar
The coolant sensor might be going bad or just gunked up. Pull the sensor and clean it, that might help.
Old Sep 4, 2007 | 02:31 PM
Camaro1996's Avatar
You say it went down an inch since last Thursday? Is it leaking anywhere? Sometimes the coolant light acts up when it gets dirty etc., its a pretty well known issue with these cars. But that doesnt mean ignore the problem, if there is one.
Old Sep 4, 2007 | 02:37 PM
BUBBA's Avatar
Get a new sensor.JMHO
Old Sep 4, 2007 | 03:03 PM
wrd1972's Avatar
Yup, they fail all the time. Pay $50 for a new one or just unplug it.
Old Sep 4, 2007 | 03:12 PM
dangalla's Avatar
i had the same problem with mine, i unplugged it until i had a chance to replace it, but i never tried to clean it and that sounds like a good idea to try first
If the level is going down, it doe not sound like a sensor problem. Fill the radiator and the reservoir to the proper cold level and check it every morning when cold for a few days.
Old Sep 4, 2007 | 06:17 PM
You have to check the level in the radiator, not in the reservoir.
Old Sep 4, 2007 | 11:31 PM
6SpdLT1Z's Avatar
probably a blown sensor. check shoebox's site he has a picture of where the sensor is located and instructions on replacing it. Very common part to fail.
Old Sep 4, 2007 | 11:42 PM
ACE1252's Avatar
Ditto that....check the level in the radiator when the engine is stone cold before startup.
Old Sep 5, 2007 | 12:09 AM
Camm95Z28's Avatar
Thanks again, great info, I will check all the angles. Thanks again for the help.
calaban
May 18, 2020 06:43 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
Sandersen511
Jan 13, 2015 03:49 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
