Low Coolant Light...Problem?
Old Oct 9, 2008 | 02:59 PM
19z28camaro02's Avatar
So my low coolant light came on the other day when I was leaving work. Stopped, went back to work so I could have somewhere to check it out. Checked the resevior, checked the radiator. Both good. Figured it was the sensor in the radiator. Well, changed that, refilled everything the correct way and re-bled the system. Light still on. Any suggestions?
Old Oct 9, 2008 | 03:20 PM
It can often take a little time for the light to go away. Make sure that unplugging it makes it go off, so you know you don't have some other problem.
http://shbox.com/1/4th_gen_tech2.html#low_coolant_lamp
Old Oct 9, 2008 | 03:23 PM
Thanks, had not thought of that.
Old Oct 9, 2008 | 07:13 PM
Unplugged it, it went off. Plugged it back in, light is off like everything is normal. Hmm.....guess this is just one I have to wait out and see if it comes back on.
Old Oct 10, 2008 | 04:59 PM
brentrich_2006's Avatar
My low coolant light came on a long time ago i found out that its a sensor behind the dash on the firewall and is a really cheap sensor but people charge alot to put it in due to the location i just didnt want to mess with it myself... but i would say that if your resi is still full not to worry about it
Old Oct 10, 2008 | 07:54 PM
The low coolant sensor is on the passenger side end cap of the radiator, right below the fill cap.
Courtesy of Shoebox:
http://shbox.com/1/low_coolant.jpg
Old Oct 10, 2008 | 09:28 PM
Must not have been on a 4th gen LT1 f-body.
Old Oct 11, 2008 | 02:10 AM
dStruct's Avatar
From what I've read and seen first hand, the low coolant sensor going out is a fairly common issue. Mine has been out since I got my car, I just unplugged it and I keep track of where my coolant levels are most of the time and check it often. It seems the sensor clogs up with gunk and triggers the low coolant light to stick on.
I think last time I checked at work (Autozone) we had them for either $35.99 or somewhere around there..
blac94Z
Feb 15, 2021 09:43 PM
calaban
May 18, 2020 06:43 PM
Fatdog2
Apr 27, 2015 10:32 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
