Loud Ticking Noise Under Hood While Engine Running
Old Jan 24, 2004 | 05:56 AM
TArider21's Avatar
Thumbs down Loud Ticking Noise Under Hood While Engine Running
Could the noise be loose rockers, and if so, would the rockers being loose make the engine run like garbage, please help, this problem of mine is getting on my nerves!
Old Jan 24, 2004 | 06:16 AM
94blackz14.2's Avatar
It could be your valves are loose but I would check to see if you have an exhaust leak first. I know that they have a very similar sound under the hood. I mad the mistake of changing my lifters out because I thought they were leaking down and low and behold it was my exhaust gasket was wearing out and leaking.
Old Jan 24, 2004 | 06:51 AM
BAD97SS's Avatar
I had a problem like this. Loud ticking noise. I took off a valve cover to find out I had about 6 spring on that side broke. Went to the other side to find a bunch more broke. Man what a noise that can make.
Old Jan 24, 2004 | 06:59 AM
TMD95Z28's Avatar
i guess its a loose rockers. as i've heard that from my car too after i had finished fixing a blown head gasket. i forgot to check some of the rockers to make sure they are tight. So one of the rockers loosen up and make that irritating knocking sounds. it might be an exhaust leaks just like 94blackz14.2 had said earlier. Try to check whether its an exhaust leaks, hopefully its an exhaust leaks.(I doubt its an exhaust leaks, as exhaust leaks doesnt sound like a knocking sound) If not it might be a loose roller rockers. IF it's not a loose roller rockers then it might be a connecting rod problem(hopefully its NOT).
just my opinion
goodluck
Old Jan 24, 2004 | 09:02 AM
I suggested the exhaust leak because he said it was a ticking noise, not knocking. If its knocking then defianetly the rockers are what I would have suggested.
Old Jan 24, 2004 | 10:30 AM
Bud M's Avatar
Check for a loose spark plug.
Old Jan 24, 2004 | 10:38 AM
Hyperspeed97z28's Avatar
I've had the plugs been loose too, makes a similar noise
Old Jan 24, 2004 | 11:23 AM
TArider21's Avatar
Thumbs up Ticking Noise
False alarm, just changed oil, and ticking noise is gone, was scheduled for oil change in a few hundred miles!
Old Jan 25, 2004 | 08:51 PM
TMD95Z28's Avatar
oops, i guess i read it wrong... u know right when its already 3 in the morning ur eyes seems to play around with you..LOL
anyway thanks for making it right for me 94blackz14.2..
Old Jan 26, 2004 | 05:43 PM
sskilla9three's Avatar
i am having this same problem...let me know what was wrong with it once you fix it.
Old Jan 26, 2004 | 07:00 PM
Its okay TMD95Z28. I know exactly what you are talking about.....how your eyes and thoughts just don't function 100% at those hours of the day.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
squarehead
Nov 21, 2014 08:02 PM
Lions3
Apr 11, 2003 10:55 AM
