Lost Coolant Bleeder Screw!
Old Aug 23, 2006 | 08:55 AM
96_Camaro_B4C's Avatar
So, after neglecting some basic maintenance for too long, last night I had everything buttoned up, finished doing my intake leak fix, plug change, K&N filter cleaning/oiling, fuel filter change. I was ready to start flushing the cooling system with distilled water, had all the connections in place. Fired the engine up (after priming the fuel system a few times), and she fired right up! I was so happy. Then I get out and look, and coolant is pulsing out of one hoses at the bleeder screw location, because I had evidently loosened one of the bleeders screws too far.
I looked everywhere (engine bay, on the engine, under the car), high and low, and can't find it. It is not on the floor anywhere I can see, so I'm assuming it is hanging out somewhere, and will probably fall out on the road sometime.
Anyway, are these little screws pretty standard? Can I pick one up at Autozone or NAPA? Or am I hosed, if you'll pardon the pun?
Help, please. My car has been down for too long while I did the intake fix and all this other maint. stuff (at least I did the TB bypass as part of the deal). I want to drive her again.
Old Aug 23, 2006 | 09:07 AM
user 647483's Avatar
Re: Lost Coolant Bleeder Screw!
Originally Posted by James Montigny
1993-1997 air bleed valve (screw) 10070107
http://shbox.com/1/bleeders.jpg
http://www.gmpartsdirect.com/
GM PART # 10070107
CATEGORY: Engine Air Cooling Control Valve
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $8.72
GMPD PRICE: $5.16
http://web.camaross.com/forums/showt...ht=bleed+screw
Old Aug 23, 2006 | 09:18 AM
Thanks. Dunno why I didn't search. I guess I wanted the venting action of typing out my sad experience.
Old Aug 23, 2006 | 09:28 AM
No problem, every thread that gets started here generates opinions from
board member and search results for someone who may not have otherwise
found their answer.
Old Aug 23, 2006 | 09:32 AM
RE AND CHERYL's Avatar
For a short term fix you can just use a 3/8 pipe thread plug.
Old Aug 23, 2006 | 09:35 AM
The dealership right up the street has one on hold for me. $6.54. Not too bad, but still frustrating since it was just a dumb mistake. Kinda like taking $6.54 flushing it down the john.
Oh well. Lesson learned.
Formula Steve
Sep 19, 2023 08:31 AM
blac94Z
Nov 4, 2015 01:59 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
HAWG
Sep 25, 2015 11:41 AM
