Loss of Power between 1k-3k
Old Feb 24, 2006 | 01:18 PM
DontMixWithRice's Avatar
96LT1/M6
(mods: pacesetter lt, flowmaster, new clutch, new slp thermo, full intake, walbro 255lph, taylor 8.5's, new gaskets on swap.)
I have a newly swapped LT1 into my 4th gen, and Ive been having an interesting problem. Ive noticed that my car is not as peppy as it was before. As a matter of fact, Ive lost a lot of low end torque, and I dont know what it could be.
I was going up a steep ramp yesterday, and typically, if i floor it, ill slide all over the place. Yesterday, I stabbed it and it was barely responding.
Any suggestions on what to check?
Also, the car has been running hotter than usual. I dont know if they have anything to do with each other.
Old Feb 24, 2006 | 01:44 PM
Z28LT1_Just_Nasty's Avatar
Re: Loss of Power between 1k-3k
Check if you have a clogged cat.
Old Feb 24, 2006 | 02:15 PM
no cats
could it be o2's?
Old Feb 24, 2006 | 03:46 PM
FastZinTennessee's Avatar
Is it bogging/stumbling or anything?? Typically with the LT1 when you have a loss of power the culprit usually ends up being some ignition problem.
Old Mar 6, 2006 | 11:39 AM
in terms of ignition:
new opti
new taylor spiro 8.5
new MSD ignition coil
maybe spark plugs??? I changed those in septmeber....they shouldnt be out! their AC delco's!!!
warmeck
May 7, 2015 02:10 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
thenewkid
Nov 27, 2014 09:41 AM
XtremeLt1
Sep 13, 2002 08:50 PM
slothgrant
Aug 22, 2002 03:01 PM
