Loss down low Problem help!!!
Old Dec 13, 2005 | 03:48 PM
bigedog8's Avatar
big stumble, now dead help!!!
My car has been acting up lately, its my car in my sig 93 firebird formula A4 just turned over 80k miles. It seems to not wanna have power down low and is sometimes inconsistent itll start off fine then seem to lose it and dip until like 3k and above then it is fine, only happens under load also, not when u just rev it in neutral. It was doing this to a smaller degree this summer and the air pump went out and replaced it and it helped it out. but also a couple of times i have been goin along nice and pushed the gas half down and the engine would just stop for a second and then id hear a pop from the drivers side and itd start driving fine again(this happens pretty fast). up top still pulls good over 3k and sometimes its perfectly fine down low too. i am perplexed because i dunno what could be wrong any and all help and suggestions would be greatly appreciated ive youve seen it before. thanks a ton
Old Dec 13, 2005 | 05:20 PM
OBE1 95Z28's Avatar
Re: Loss down low Problem help!!!
How old are the spark plug wires; look under the hood in the dark with the engine running; see if there's any arcing from the spark plugs wires to the block.
Old Dec 13, 2005 | 05:30 PM
corbraeater's Avatar
yea check your wires, and makesure there not acring. i had the same problem and i change the wires,plugs, and optispark, and it never did it again.so give that try
Old Dec 13, 2005 | 05:54 PM
bigedog8's Avatar
alright ill give the simple stuff a try, im at school so i dont have a garage or n e thing or a bunch of tools, but i work at autozone so i was planning on borrowing a spark plug socket n checking out some plugs, ill check the wires n stuff to, its finals week so i havent had a ton of time, hopefully its something simple. it all started one day i parked my car came out and started it and it just stumbled for a bit and i backed out stumbling and then it cleared up so i dunno ill go check the wires tonight.
Old Dec 13, 2005 | 06:30 PM
bigedog8's Avatar
i just went out n checked for arcing, no arcing anywhere looked for a good while revved it up to look, i checked all over and didnt see anything at all the whole time. ill check out the plugs but i just pulled some not very long ago to check em out and they looked good. but if it indeed could be the opti which is commom then the plugs might be getting fouled from that if they look bad now. ill check em out tho. ive been reading about all this and there will never be a definite answer lol.... but hopefully i can figure something out. if you have n e more helpful advice throw it at me. thanks
Old Dec 13, 2005 | 07:43 PM
94blkramair's Avatar
could be your 02 sensers, just a thought.
Old Dec 13, 2005 | 09:42 PM
bigedog8's Avatar
the SES light isnt on n e one think i should take it in and see if it has any stored codes? and can just an OBD1 scanner from like advance do that?
Old Dec 13, 2005 | 09:49 PM
bigedog8's Avatar
my car isnt putting out much heat from the vents so im believing my heater core might be getting plugged and my coolant system needs flushed, think that might be messing with the water pump and have something to do with it? car has been runnin around normal temp but fluctuates weirdly occasionally goes down or up to the halfway point at 220 on the gauge. just trying to give more info
Old Dec 14, 2005 | 11:50 AM
bigedog8's Avatar
any more suggestions? im guessing opti but ill check everything else.
Old Dec 14, 2005 | 02:43 PM
bigedog8's Avatar
its a lot wetter and more humid cuz its crappy outside today and its stumblin more. talked to a buddy that knows a lot about cars and fbodies, gave him a ride and he says opti so thats what im goin after. 80k is enough miles to have a bad opti so ill get on it and let u know if that was it... im hopin thats it at least. checked the plugs n wires n stuff n no problems with em so im guessin the opti is going down
Old Dec 14, 2005 | 06:07 PM
bigedog8's Avatar
its really rainy out and now it starts up stumbles n dies. looks like im gonna be replacing the opti
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Cam's maro
Mar 24, 2015 08:09 PM
grabbem88
Mar 18, 2015 01:25 PM
slothgrant
Aug 22, 2002 03:01 PM
