Losing oil pressure at low RPMs
Old Oct 22, 2004 | 08:57 AM
OutKast's Avatar
This just started yesterday on my way home from work. Noticed the pressure would drop to nothing when the RPMs dropped below 1k. As long as it stays above 1k everything is fine. I've got two guesses the first being the obvious oil pump failure. My second is something I read about a while back about oil filters failing (some sort of check valve or something) causing a similar condition.
Going to change the lube and throw on a new filter shortly but I'm hoping someone has a little input for me.
Changing an oil pump to find out a bad filter caused the problem might be as bad as pulling the tranny to find out I busted another 10-bolt. No need to go there.
Old Oct 22, 2004 | 09:01 AM
Schweet97Z's Avatar
Re: Losing oil pressure at low RPMs
what kind of filters do you use????.......if its a fram change it and put something else in there!!!!!.....i use K&N and have had nothing but great oil pressure with them!!!......i would rule out the oil pump for now since you get pressure at rpms about 1000.....your filter is probably clogged......good luck and keep us posted
Old Oct 22, 2004 | 09:15 AM
OutKast's Avatar
I've got a Purolator (Pure One) in it right now. Will try a K&N next. I've used Fram for years (father is a Fram distributor) and haven't had a problem with them although I have seen all the posts about them and the low quality materials used in manufacturing.
Old Oct 22, 2004 | 09:49 AM
izzyz28's Avatar
If it's not the filter then it's probably the oil pressure sending unit. put a mechanical gauge on it and find out for sure.
Old Oct 22, 2004 | 11:25 AM
crazy_jackalope's Avatar
tell me when you find out what this is. My car does the same thing. I've never heard about Fram's filters sucking. What kind of filter should we use?
Old Oct 22, 2004 | 11:27 AM
blwnlt4's Avatar
it may be as simple as being low on oil
Old Oct 22, 2004 | 12:27 PM
StickMaster's Avatar
CHeck your oil pressure sending unit (94,95 on back of intake or around there) my was cracked and wasnt reading correctly, about the same as you describe, i started flipping out, but turned out to be only a 20 part and oil pressure was really fine.
Old Oct 22, 2004 | 01:01 PM
OutKast's Avatar
Ended up putting on an AC Delco PF454 and some new oil and it seems okay now. If I see it again I check the sender. I remember one time I was at the track and broke the sender...didn't know it and had it towed home ($150) only to find it was a $20 fix and I could have driven home.
HectorM52
Jul 30, 2017 11:46 AM
Cam's maro
Mar 24, 2015 08:09 PM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
