Losing coolant...from the radiator cap.
Old Mar 19, 2011 | 08:18 PM
Colin's Avatar
Hey guys,
I have a '93 LT1/T56 in a '72 Chevy Vega. I am running a manual transmission radiator with an 18lb radiator cap. The car doesn't have an overflow tank at this point in time. The cap is the new, and the radiator was recently tanked. I have the steam line entering into the radiator at about the same height as factory.
I am losing about half a gallon of coolant per day. I can see that it's coming out the vent hose on the radiator. I've been diligently refilling it, but I know this isn't normal. Can anyone help me pinpoint the problem? Am I running the wrong cap pressure? Need a pressurized overflow tank with a lower pressure cap?
Thanks,
Colin
Old Mar 19, 2011 | 09:34 PM
Re: Losing coolant...from the radiator cap.
Its perfectly normal to lose coolant when you don't have a reservoir (overflow tank). The purpose of the reservoir is to catch the coolant that normally flows out of the radiator cap when the coolant heats up and expands. If you had a reservoir, as the coolant cooled down and contracted, the resulting vacuum would pull the overflow out of the reservoir to keep the radiator full. But yours is blowing the coolant out on the ground when the coolant heats up, and sucking air back in when the coolant cools down.
Old Mar 19, 2011 | 10:06 PM
Colin's Avatar
Fred,
Thanks for the really quick reply. Should I run a pressurized reservoir or will any suffice?
Old Mar 19, 2011 | 10:13 PM
No. You keep the 18psi cap, and use an atmospheric reservoir. The overflow tube from the radiator has to reach all the way to the bottom of the reservoir.
Old Mar 19, 2011 | 11:55 PM
Colin's Avatar
Fred,
Perfect! I'll look for a stock reservoir for my Vega. I'm sure one of the members on my site will have one. I appreciate the help.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Pwilson59
Sep 3, 2015 08:47 PM
