loose of TQ after jet hot install HELP
Old Jun 18, 2004 | 09:20 PM
lethal93ta's Avatar
I just got done putting a set of jet hot long tube headers and a hooker Y pipe on my 93 procharged TA , now it seams to have lost a lot of TQ I watched my knock sensor on a scanner and its not seeing any knock that was my first thought it just feals dead on the bottom end, it pulls hard up top for the most part. any ideas guys.
Old Jun 18, 2004 | 09:54 PM
Spinner's Avatar
Sounds like you might have switched two of the plug wires, or have a bad wire
Old Jun 19, 2004 | 09:20 AM
lethal93ta's Avatar
it dont miss at all tho, just no TQ on the bottom end.
Old Jun 19, 2004 | 10:55 AM
WS Sick's Avatar
Do you have dyno before? dyno after and see if its in your head or real. Noise makes the mind do wierd things.
Old Jun 19, 2004 | 12:17 PM
lethal93ta's Avatar
I know that its not in my head this is a major loose, before I could just floor it and spin till third gear now it just spins a little bit in first thats it.
Old Jun 19, 2004 | 01:26 PM
HBHRacing's Avatar
How bad is the header leak Ron? it might be sucking air into the exhaust and making the 02 read lean and adding more fuel then you need. Usualy you lose some lower end but with the boost your running I am little suprised it would be that much.
Old Jun 19, 2004 | 01:42 PM
lethal93ta's Avatar
I can hear it leaking a little bit its not real bad I just got another set of gaskets im going to put on to try to fix it, but I dont think that little leak would make for this kinda power loose
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
LT14LIFE
Feb 9, 2015 09:35 PM
ANDYZ28
Dec 29, 2014 09:13 PM
bandit383lt4
Dec 21, 2014 09:12 PM
