Loose steering
Old Jul 11, 2003 | 07:04 AM
ProtoX's Avatar
Loose steering
I have a 95 camaro with 130k. When I'm driving down the road it has a loose spot in the steering. When you move a little left or right nothing happens. What do you think this is?
Old Jul 11, 2003 | 07:31 AM
BitCypher's Avatar
First, check your tie rods to make sure that they are not worn out. VERY IMPORTANT.
Second, if those are fine then more than likely the rag joint in your steering linkage (the linkage is visible right beside the driver-side manifold/header) is worn out. GM's way of fixing a worn rag joint is to replace the entire steering linkage - which is roughly $100. Some opt to hit up a salvage yard to find a replacement and other simply buy an after-market part called the "rag joint eliminator" and simply repair their existing linkage. Do a search on "rag joint" in this forum and you'll find the web links.
Old Jul 11, 2003 | 07:33 AM
ProtoX's Avatar
Thanks for the help!
Old Jul 11, 2003 | 09:55 AM
OffspringZ28's Avatar
www.unbalancedengineering.com
rag joint eliminator for 30 bucks.............bingo
HibachiZ28
Nov 6, 2015 12:53 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
rideordie
Sep 7, 2015 08:22 AM
War Engine
Aug 28, 2015 06:04 AM
Schul365
Aug 25, 2015 05:47 PM
