Loose rocker cause high rpm miss and idle prob?
Old 10-13-2003, 07:10 PM
96z
96z's Avatar
I havent had a chance yet to pull the valve covers but there is ALOT of clacking coming from underneath there. Supposing there is a loose rocker arm(s) would that cause a predictable high rpm miss and irratic idle?
Why wouldnt a loose rocker cause a miss at low RPM?
96z is offline
Old 10-13-2003, 09:47 PM
96z
96z's Avatar
Anyone have an idea?
96z is offline
Old 10-13-2003, 09:59 PM
96speed's Avatar
PDM: Had this same problem. Turned out to be the dowel on the cam was 3/32s too long - tore up the opti. It could be a few things, but this is going to be my number one check for this problem from now on.
Ryan
96speed is offline
Old 10-14-2003, 12:03 AM
96z
96z's Avatar
Ryan I actually had this problem in the spring and had to buy a new opti because of it. Now its plenty short.
96z is offline
Old 10-14-2003, 01:03 AM
AndyCLT1's Avatar
I thought I was the only one with rocker problems Dave. What you described is exactly what had happened to mine a few times. Remember helping me adjust them at the track? Sounds like my car.
Andy
AndyCLT1 is offline
Old 10-14-2003, 09:00 AM
96z
96z's Avatar
Andy
Andy, did you have a miss and bad idle when your rocker(s) were loose?
96z is offline
Old 10-15-2003, 02:47 AM
AndyCLT1's Avatar
Yeah, and I definitely noticed slower 1/4 mile times too.
Andy
AndyCLT1 is offline
Old 10-15-2003, 04:01 AM
aintno6's Avatar
A week before my bad lifter issue, my car would had this odd idle like it was missing. And it would kinda do the same thing in low rpms every once in a while. Well that ended up collapsing which caused a bent valve.
You may be having the same issue, or you may have somthing else. All I know is take care of it ASAP.
aintno6 is offline
Old 10-15-2003, 03:38 PM
96z
96z's Avatar
My lifters should be alright, they are comp R's. Actually all of the rockers were a little loose with a couple a more than the rest. I changed the coil too and Ill see if that doesnt help anything.
96z is offline
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
armedtrigger
02-24-2015 08:30 PM
Fatdog2
02-13-2015 08:19 PM
DetroitZ28
02-13-2015 07:33 AM
Quick Reply: Loose rocker cause high rpm miss and idle prob?
