loose rocker arms
i know, i looked... i dont see it. It says rocker arm (stud) 50 ft-lbs and rocker arm cover bolts 106 in-lbs. WOULD A SIMPLE ANSWER HURT ANYONE. I tryied to find it, im not a good searcher.
As stated above, they're not torqued down. Depending on the position of your cam, some rockers will be tighter than others when you pull the valve covers. Shoebox has a good description of the process here:
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
