Loose header bolts
Old May 5, 2003 | 11:59 AM
jcolez28's Avatar
Loose header bolts
My header bolts keep loosening and twice have fallen out, causing the gaskets to go. Has anyone used torque seal?
Old May 5, 2003 | 03:53 PM
EviLBoX's Avatar
You should check out Stage 8 locking bolts, I'm using those with my headers and haven't had a problem with them backing out.
Old May 6, 2003 | 06:05 AM
IDOXLR8's Avatar
Another vote for Stage 8 header bolts.
Old May 6, 2003 | 07:50 AM
DR.ZED's Avatar
Are you using 1" header bolts, or 3/4"?
I switched to 1" bolts. Torqued them down another 1/4 - 1/2 turn a few heat cycles later. (About 100 kms driving over 3 or 4 trips).
Old May 6, 2003 | 10:18 AM
magius231's Avatar
how did you install them, did you torque them in once and forget about it? If you did thats your problem...I put mine in, tightened them after the first heat cycle, then tightened them again after another. After that I check em once a week and none have loosened yet (ARP Stainless header bolts)
Old May 6, 2003 | 11:01 AM
ShelbyZ28's Avatar
I did the same and have not had any problems. My header bolts haven't loosened since the first week after the install.
Bryan
Old May 6, 2003 | 11:33 AM
Robbie's Avatar
I used ARP 12 pt bolts. Tightend them through about a week of cycling heat and haven't backed out since. Did you tighten them everyday for about a week?
Old May 6, 2003 | 01:24 PM
jcolez28's Avatar
I used 1 inch and have tightened them several times. Will lock washers work or torque sael work? Thanks.
Old May 6, 2003 | 01:36 PM
Blk94Z28LT1's Avatar
use 1" stage 8 locking header bolts. Tightned mine up one time when installing headers, no problems since.
Old May 6, 2003 | 07:57 PM
Bud M's Avatar
I use Stage 8s with anti sieze. No problems.
Victor Lamb
Aug 26, 2017 02:52 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
