looking for a cam setup
It almost winter again...
so its time to start thinking mods
. Last winter I did all the suspension work and now this year I'm thinking about throwing in a cam. Basically I need everything that goes along with the cam. Okay, now. you ask what do I want out of this cam ???
>I want a street-able cam, I drive around 5k miles a year
>I want more low end grunt and more pull up high
>emissions are not a problem
>I want a bit more lopey idle than stock.
> my budget is 1000-1500 for parts...i want something that's reliable
>what about the supporting mods like roller rockers? springs? pushrods? timing chain? guide plates? ect ect
>I would like to keep the stock converter for now...
thanks for all the help !
~Greg
. Last winter I did all the suspension work and now this year I'm thinking about throwing in a cam. Basically I need everything that goes along with the cam. Okay, now. you ask what do I want out of this cam ??? >I want a street-able cam, I drive around 5k miles a year
~Greg
if you want to keep the stock convertor then the lt4 hotcam kit, then some stronger springs, the springs that come with the kit arent strong enough. either that or a cc305 and supporting kit.
Imean I will be changing it out sometime next year or so, as long as its some what drivable for the time being. I don't want to put something in I wont like just cause of the converter.
thanks !
~GREG
thanks !
~GREG
Cams are an excellent example of TINSTAAFL. You cannot get both more at low end and the high end by changing cam specs. One will alwys be at the expense of the other. However, if you combine the right converter with the right cam, you may see improvements at both ends. You can probably re-use your stock pushrods.
Rich
Rich
Okay, I'm thinking hotcam and with the money I save I'll get a stall and better valve springs. Which brings me to my next question, what are your recommendation on springs and stall ?
~Greg
~Greg
Rich
Xtreme Energy™ 276HR-12
Comp Cams part number 07-503-8
224/230 112
new springs
new lifters
This is the cam I am running in my 94 stock intake and stock heads set up. I have not dyno tested it yet but I do have a desktop dyno and it read the strongest for a stock head stock intake setup.
224/230 112
new springs
new lifters
224/230 112
new springs
new lifters
224/230 112
new springs
new lifters
Rich
