looking for a cam setup
Old Aug 21, 2009 | 06:43 AM
transAMdriv3r's Avatar
It almost winter again... so its time to start thinking mods . Last winter I did all the suspension work and now this year I'm thinking about throwing in a cam. Basically I need everything that goes along with the cam. Okay, now. you ask what do I want out of this cam ???
>I want a street-able cam, I drive around 5k miles a year
>I want more low end grunt and more pull up high
>emissions are not a problem
>I want a bit more lopey idle than stock.
> my budget is 1000-1500 for parts...i want something that's reliable
>what about the supporting mods like roller rockers? springs? pushrods? timing chain? guide plates? ect ect
>I would like to keep the stock converter for now...
thanks for all the help !
~Greg
Old Aug 21, 2009 | 07:44 AM
96' Formula WS6's Avatar
if you want to keep the stock convertor then the lt4 hotcam kit, then some stronger springs, the springs that come with the kit arent strong enough. either that or a cc305 and supporting kit.
Old Aug 21, 2009 | 11:09 AM
Imean I will be changing it out sometime next year or so, as long as its some what drivable for the time being. I don't want to put something in I wont like just cause of the converter.
thanks !
~GREG
Old Aug 21, 2009 | 11:15 AM
slomarao's Avatar
I would really do cam, stall, gears all at the same time. You really want to match the 3 to get the best result. Between all 3, with traction you could shave .8-1.3 off your et.
Old Aug 21, 2009 | 11:37 AM
rskrause's Avatar
Moderator
Cams are an excellent example of TINSTAAFL. You cannot get both more at low end and the high end by changing cam specs. One will alwys be at the expense of the other. However, if you combine the right converter with the right cam, you may see improvements at both ends. You can probably re-use your stock pushrods.
Rich
Old Aug 21, 2009 | 08:36 PM
Okay, I'm thinking hotcam and with the money I save I'll get a stall and better valve springs. Which brings me to my next question, what are your recommendation on springs and stall ?
~Greg
Old Aug 21, 2009 | 10:05 PM
rskrause's Avatar
Moderator
~Greg
I think a stall speed in the 3,000rpm range would suit the hotcam pretty well. Get the kit, less than $600 for the cam, matching springs, retainers, aluminum 1.6:1 rockers.
Rich
Old Aug 21, 2009 | 10:49 PM
doug1105's Avatar
First off, you're in PA
There's not enough straight road to wind out a huge cam.
Hotcam will kick a$$
Old Aug 22, 2009 | 04:32 PM
reamo04's Avatar
i would skip the hotcam, and buy the lingenfelter 219/219. it is, IMO, amuch better cam, but than you have to source out the rest of the parts. Otherwise the hotcam is still a good kit.
Old Aug 24, 2009 | 07:57 PM
curious on why you think its better ? where can you get one new ?
Old Aug 24, 2009 | 10:35 PM
SlowMoComotion's Avatar
Xtreme Energy™ 276HR-12
Comp Cams part number 07-503-8
224/230 112
new springs
new lifters
This is the cam I am running in my 94 stock intake and stock heads set up. I have not dyno tested it yet but I do have a desktop dyno and it read the strongest for a stock head stock intake setup.
Old Aug 24, 2009 | 11:03 PM
rskrause's Avatar
Moderator
224/230 112
new springs
new lifters
I am not criticizing your cam choice. But using DD to pick a cam is not what I would recommend.
Rich
Old Aug 24, 2009 | 11:27 PM
red94chicken's Avatar
cc503's have been known to be a great cam. +1 on desktop dyno sucking a butthole.
Old Aug 24, 2009 | 11:42 PM
Bersaglieri's Avatar
Start looking at the HOTCAM, CCC305, GM846, and the XE503. Do a bunch of searches to see how folks liked them, hear what they sound like, and what they used for a supporting mods.
-Dustin-
Old Aug 24, 2009 | 11:45 PM
TBSPW's Avatar
go to advanced inductions...they sell a great package...fits right in your price range too.
