Looking to buy a trans temp gauge.Which one
Old Jun 28, 2005 | 07:36 PM
5H9D0W's Avatar
Mechanical or Electric Full or short sweep. Pros and Cons.I don't really know the difference between the two so If someone can school me that would be great.
Old Jun 29, 2005 | 09:07 AM
Re: Looking to buy a trans temp gauge.Which one
Running a mechanical temp gauge is a bit of a problem, since you have to route the capillary tube from the tranny connection to the interior of the car. Electronic is fine. I ran out of A/C holes in the dash, so I used 2-1/16" 1/4-sweep elctronic gauges in the A-pillar for oil and tranny temp.
http://cjcfo.fbody.com/members/injun.../DCP03652a.jpg
Old Jun 29, 2005 | 11:02 AM
5H9D0W's Avatar
Hey Inj,You have an automatic w/ a monster tach.How do you utilize that thing.I want one but don't know if it's worth it.I would like a shift light to run on a roll.These transmissions love to go to OD @ like 40mph.How do you have your shift points setup like right before 5,800 or somethin'.
BTW Shweet Shetup
Old Jun 29, 2005 | 05:36 PM
The B&M Pro-Ratchet shifter controls a manual reverse-pattern valve body on a TH400 tranny. Since the trans can't shift itself, I have to know when. The stock tach is sort of useless, because I'm running a solid roller cam, a 7,200rpm redline and spraying a 300-shot off the line. You'd be surprised how fast redline comes up with that kind of power off the line, so the shift light helps.
And, being a certified senior citizen, the 5" AutoMeter is a little easier to see than the factory tach...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 10:44 PM
