Longtubes Question
Old Apr 26, 2008 | 09:30 PM
MTBSully's Avatar
Longtubes Question
I should be doing my LT install next weekend and i was wondering if anyone on here has ever made their own o2 extensions? How hard was it?
Also what is involved in removing the AIR pump? Should i take it out completely or just find a bolt to block up the manifold fitting?
Also any good write-ups with pictures of LT installs would be great. Thanks
Old Apr 26, 2008 | 10:49 PM
ss.slp.ls1's Avatar
If you don't have to pass inspection, you can remove the air and egr and use block off plates. You will get a code unless you get them tuned out. I'm looking for write ups on an fbody headers install too.
Here's an install on a C5:
http://www.ls1howto.com/index.php?article=29
Old Apr 26, 2008 | 11:21 PM
With the OBD-I 95, if you remove the AIR pump, all you have to do is make sure there is a good fuse in the AIR pump circuit, and you will not get a code.
WildRidez
Mar 27, 2015 08:22 AM
armedtrigger
Feb 24, 2015 08:30 PM
alphaauto
Parts Wanted
Jan 23, 2015 06:17 PM
k1996z28
Jan 21, 2015 07:22 AM
