Lokar Dipstick Install problems
Old Jun 30, 2007 | 04:38 PM
87camracer's Avatar
I got the lokar dipstick part number ED-5001 and am having a problem install it. Mine just loosely fits into the block and it doesn't register an oil on it at all. There are 5 qts of oil in it for sure (just put them in to prime the engine) and no matter how I put the dipstick into the block it never registers oil. What am I doing wrong?
Old Jul 1, 2007 | 01:15 PM
87camracer's Avatar
Not one response?
Old Jul 2, 2007 | 11:42 AM
Casey_SS's Avatar
First thought that comes to mind is your oil pan. You mention priming the motor, indicating a fresh build....are you using an aftermarket oil pan? If so, those are typically higher capacity than stock (6-7 quarts) and the 5 quarts you put in probably are not enough to register on the stick.
If you're running a stock oil pan, check to see if the end of the dipstick is intact...I tried a Lokar with my header install and my crankshaft bit an inch or so off the end the first time I fired it up. Had to go back to a stock dipstick...PITA to route around the headers but no other problems.
HectorM52
Jul 30, 2017 11:46 AM
97Z28Muscle
Feb 6, 2015 10:44 PM
97SSdude
Dec 31, 2014 07:43 PM
yosshimura
Aug 12, 2002 06:47 AM
Chrisdude
Jul 24, 2002 02:25 PM
