Lokar Dipstick
Old Jan 28, 2004 | 01:18 PM
1995ta's Avatar
Question Lokar Dipstick
The one from Jegs' website says for SB Chevy's 1980 and up, will this still work for an LT1? I want to be sure before I purchase it this week.
Old Jan 28, 2004 | 02:07 PM
simple's Avatar
yes. got one on mine and it fit, cept i had to mount it to the 2nd to last header bolt on the passenger side instead of the 3rd to last
Old Jan 28, 2004 | 02:46 PM
fastcamz28's Avatar
Ditto "Simple's" response! Mine in for a year now.
Old Jan 28, 2004 | 02:52 PM
CamaroBoy96Z28's Avatar
I have it too. Still have to put it on though.
Old Jan 28, 2004 | 03:53 PM
97FormulaWS-6's Avatar
Same here, my stocker's leaking like a siv from the LT install...
Old Jan 28, 2004 | 04:06 PM
ibanez6rg's Avatar
I got one to install, since I broke the stock one.
Old Feb 5, 2004 | 02:00 PM
1995ta's Avatar
Well, I just got mine, it looks awfully short. Hopefully it will work. Exactly how much shorter is the Lokar than the stock dipstick? I dont want to be reaching right at a primary to check my oil...
Old Feb 5, 2004 | 02:53 PM
dreamer1q's Avatar
I had one and found two problems. First it is really short, that sucked. Second, it dosnet fit real well with a Canton (piece of crap) oilpan. In fact it ate the tip of it off on the crank due to the different on the pan. And no, I dont have a stroker. So it is definetly due to the pan
Q
Old Feb 5, 2004 | 02:56 PM
1995ta's Avatar
So how short is it? Good thing I dont have an aftermarket oil pan...
Old Feb 5, 2004 | 04:08 PM
Fastbird93's Avatar
REAL short. I tried one, and couldn't get it to fit with my ASM headers. Had to make do with the stocker.
Old Feb 5, 2004 | 04:09 PM
1995ta's Avatar
You guys tell me now. Hopefully it'll work with Hooker Super comps...
Old Feb 5, 2004 | 04:29 PM
simple's Avatar
works good with my Hooker LT's, if that what you mean buy Hooker Super Comps?
it works good and is a tad bit short to reach but i figure if you need to check your oil it needs changed anwyay!
its still EZ to get too tho
Old Feb 5, 2004 | 04:39 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Mine is too short and you burn the F**k out of your hand when you check the oil.... i think they sent me the wrong one..... At least my car doesnt leak or burn oil, therefore i dont have a need to check it.....
Chris
Old Feb 5, 2004 | 04:41 PM
ibanez6rg's Avatar
Well then, I hope it works with Jet-Hots.
