Lokar Dipstick
Well, I just got mine, it looks awfully short. Hopefully it will work. Exactly how much shorter is the Lokar than the stock dipstick? I dont want to be reaching right at a primary to check my oil...
I had one and found two problems. First it is really short, that sucked. Second, it dosnet fit real well with a Canton (piece of crap) oilpan. In fact it ate the tip of it off on the crank due to the different on the pan. And no, I dont have a stroker. So it is definetly due to the pan
Q
Q
Originally posted by Fastbird93
REAL short. I tried one, and couldn't get it to fit with my ASM headers. Had to make do with the stocker.
works good with my Hooker LT's, if that what you mean buy Hooker Super Comps?
it works good and is a tad bit short to reach but i figure if you need to check your oil it needs changed anwyay!
its still EZ to get too tho
From: Austin, TX or Texas State University at San Marcos
Mine is too short and you burn the F**k out of your hand when you check the oil.... i think they sent me the wrong one.....
At least my car doesnt leak or burn oil, therefore i dont have a need to check it.....
Chris
Chris
