Location of oil pump pickup
Old Aug 5, 2005 | 08:03 AM
2000GTP's Avatar
Hey everyone, the previous owner of my car cracked something pretty good because the k-member, oil pan, and old y-pipe all are dented. The oil pan is recessed some at the end of the pan. I am curious as to where the pickup tube is located. Is it around the drain plug area in the middle of the pan. Should I have new pan installed or just see what happens?
Old Aug 5, 2005 | 11:40 AM
1racerdude's Avatar
Re: Location of oil pump pickup
The pickup is about dead center and 1/2" off of the floor. Pull the pan and beat it out and check for leaks.
Old Aug 5, 2005 | 12:43 PM
2000GTP's Avatar
Good, the dent is nowhere near the pickup tube then but it is still something I would like to address. Do you know of any tricks that I can do to get the pan off with a floor jack or should I rent or buy a cherry picker and pull the motor up some?
Old Aug 5, 2005 | 04:34 PM
1racerdude's Avatar
Ta can pull it by jacking the engine up.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
