LME head porting work on my AFR-210s
Old Jun 12, 2006 | 09:25 AM
  #16
JustNO's Avatar
Re: LME head porting work on my AFR-210s
My 210cc AFRs flowed 282cfm @.600 (out of the box). They published 288cfm @.600 on their website.
Old Jun 12, 2006 | 11:21 AM
  #17
streetrod93's Avatar
first off, props to the numbers those heads now flow
next, i think you're mistaken on the type of head you bought....the competition are the better flowing head vs/ the race ready. @ .700 lift the competition flow 297 according to AFR site where as the race ready on flow 272...a drop from .650 (275).
all of this is now arbitrary concidering the port work done...because those flow numbers are awesome
Old Jun 12, 2006 | 11:28 AM
  #18
one question on the short block....what brand piston are those...and what are the specs on your cam...i noticed you said solid roller setup, and that's where my 383 is headed. i was curious as to how far you had to fly cut the pistons to clear the valves.
Old Jun 12, 2006 | 01:08 PM
  #19
user 647483's Avatar
Wow, very nice
Old Jun 12, 2006 | 02:45 PM
  #20
96speed's Avatar
Majorly bling! Is this an NA street/raceonly setup? What are your power goals?
Looks good so far. The valve springs look like jewelry .
Ryan
Old Jun 12, 2006 | 02:51 PM
  #21
Brettinator's Avatar
thanks Bro, got my names backwards I guess, thanks for the correction.
Old Jun 12, 2006 | 02:54 PM
  #22
The pistons were JE/Wiseco "one/offs" for this build, cam is a custom grind for this build, pretty crazy duration, 110cl and around .691 lift, not sure what they cut the pistons to.
Old Jun 12, 2006 | 02:55 PM
  #23
Ryan
Thanks man, I'm the local n/a guy, everyone around Houston is turbo, SC or nitrous, I'm really into getting all I can out of an LT1 prior adding nitrous with the 12:5:1 comp. I'm hoping for 500 rwhp with this setup and higher when I do the SuperVic and bigger heads, will find out sometime this week how she does, hopefully tomorrow.
Old Jun 12, 2006 | 03:26 PM
  #24
96speed's Avatar
Oh cool, you're local .
Good luck.
Ryan
Old Jun 12, 2006 | 05:18 PM
  #25
marshall93z's Avatar
What intake you running for now?
Old Jun 12, 2006 | 06:34 PM
  #26
how much did they charge for the port work?
Old Jun 13, 2006 | 09:06 AM
  #27
Had them go through my LT4 intake and clean it up make it look like the heads, I had ported it myself prior, but they raised the runners just a little to match the heads better and cleaned it up further inside as well as the TB opening and injector ports.
Old Jun 13, 2006 | 09:23 AM
  #28
Sweetred95ta's Avatar
The port work looks really good. Your car should run like like a bat out of hell.
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
Killer94z
Jan 13, 2015 12:06 PM
