LME head porting work on my AFR-210s
Old Jun 10, 2006 | 03:24 PM
Brettinator's Avatar
My other post had it's pic limit of 10 I guess, but some of you were asking about the heads, so here's the MAXPORTING work Brian & Pecos @LME did for me. Out of the box AFR-210s flowing 272 @.700 intake according to AFRs website. LME did the port work, I'll have the engine blueprinting Monday along with the baseline #'s before/after their porting. LME got a solid 30-cfm across the entire band, intake now flows 315 @ .700 intake which I'm happy about because AFR-227s are 309 @.700. They also swapped out the AFR valves for Ferrera Comp Race valves, opened up the seats for some monster Manley Nextek springs for the solid roller, titanium keepers, 5-angle race valve job, decked, etc, etc. They also cleaned up the porting I did on my LT4 intake, opened up the runners, injector angles & port matched to the new heads runner sizing.
Old Jun 10, 2006 | 03:33 PM
Sinister95Z's Avatar
Re: LME head porting work on my AFR-210s
All I can say is....DAMN!
Old Jun 10, 2006 | 04:26 PM
Cerwin Vega Fan's Avatar
X2!
Old Jun 10, 2006 | 06:19 PM
30696bird's Avatar
X3 X4 X5 The whole set up looks GREAT.
Old Jun 10, 2006 | 06:20 PM
luckyou03's Avatar
huminafuminahuminahumina
Old Jun 10, 2006 | 07:03 PM
IllusionalTA's Avatar
Gangsta!!!.. **** look's good man.. !!! What lifter's are you running?
Old Jun 10, 2006 | 07:13 PM
OUTCAST's Avatar
Looks killer what is the website LME? I like them to do some work on my heads!
Old Jun 10, 2006 | 10:18 PM
LT4POWR's Avatar
Looking good Post the flow sheet.
I'm assume he's talkin about http://www.livernoismotorsports.com/ They are pretty popular on LS1Tech.com
Old Jun 10, 2006 | 11:44 PM
Dave69Z's Avatar
I believe he is refering to LME out of Houston.
Late Model Engines
Houston, 77041-5641
Local phone: (713) 849-4505
Fax: (713) 856-5787
http://www.latemodelengine.com/
Old Jun 11, 2006 | 06:59 AM
Late Model Engines
Houston, 77041-5641
Fax: (713) 856-5787
That is correct.. LME has done some great work for a buddy of mine as well... def. a top notch operation from what i have seen so far..
Old Jun 11, 2006 | 08:15 AM
Kevin Blown 95 TA's Avatar
Look at the pictures of the head surfaces where AFR has the seats blending into the head surface - you can see where the fly cutter chatters across the seat a little bit because it was just cutting aluminum, then all of a sudden it hits harder metal. One good trick there is to have them grind down that part of the seat just slightly below the surface of the aluminum before surfacing so you get a smooth cut across the entire head. Or you could use a grinder to surface it instead and get it nice and smooth. Probably doesn't matter much, but just one of the little details that came up during my build. Absolutely an outstanding setup BTW.
Old Jun 11, 2006 | 10:41 AM
OUTCAST's Avatar
Thanks guys for the info. LT4POWR how you been doing long time man.
Old Jun 11, 2006 | 01:25 PM
Dave69Z's Avatar
Bernie,
You ever get your 210s flowed? Were your heads the Race Ready's or Competitions?
Dave
Old Jun 11, 2006 | 01:31 PM
regorih inHous.'s Avatar
Hey what did the heads flow at .600 lift??
Old Jun 12, 2006 | 08:39 AM
Thanks for the tip, lost me a little but think I understand, note taken. Thanks for the props everyone, I don't get on the net unless I'm at work, gave my laptop to my son for college recently so hard to reply. I'll post the flow #s, don't remember @.600 what it flows, should have the paperwork today though, these 210s were just the Comp not Race Ready, didn't have enough $$ at the time, the Race Ready would not have been worth the extra $$ anyway from what I've learned since then, but who knows. Anyway I'll post the info if I get it later today.
