Lloyd Elliott Heads/Cam packages info inside (for those interested)
Old Oct 24, 2004 | 08:44 PM
  #31
99BlackTA's Avatar
Re: Lloyd Elliott Heads/Cam packages info inside (for those interested)
I am curious about why these setups will only last 20-60k miles? Is it like that with any set of heads? I am looking at just getting some heads at the moment but I want them to last a loooong time.
Old Oct 24, 2004 | 09:02 PM
  #32
dmoor88's Avatar
setups will last as long as you take care of them. TYPICALLY, and i know im going out on a limb here , youll want to run your car a little harder after you get a h/c package. this will wear your engine quicker than if you had just taken it easy and not decided on a h/c combo.
Old Oct 24, 2004 | 09:04 PM
  #33
Hybrid86Z's Avatar
I have one question, will the LE3 heads work well with a LT4 intake over the LT1?
I'm contemplating getting an LT4 intake, but if it's not needed, I won't get it
Old Oct 24, 2004 | 09:06 PM
  #34
dmoor88's Avatar
you need lt4 heads to use an lt4 intake.
Old Oct 24, 2004 | 09:20 PM
  #35
turbo_Z's Avatar
If you get a real high lift cam then you need to replace the valve springs every 30k or so. I am not very familiar with Joe O cams so I cant say for sure if thats going to be an issue. Staying with a low lift cam... say under .580 lift should last a long while.
Old Oct 24, 2004 | 09:21 PM
  #36
dmoor88's Avatar
joes cams have lower lifts than a lot of other cams. i think theyre all below .600"
Old Oct 24, 2004 | 09:24 PM
  #37
Hybrid86Z's Avatar
ahh didn't know that. i will stick w/ my LT1 then.
430rwhp on an LE3 setup with all the boltons, electric wp, 58mm TB, longtubes and true duals sounds badass to me
Old Oct 24, 2004 | 09:26 PM
  #38
dmoor88's Avatar
thats what im preachin man! and with a good tune it can be very streetable.
Old Oct 24, 2004 | 11:29 PM
  #39
SStrokerAce's Avatar
Actually .600 lift and lower on a street car is ok as long as the system is designed for it.
Replacing springs every two years is good to do to be on the safe side.
Bret
Old Oct 24, 2004 | 11:34 PM
  #40
dmoor88's Avatar
esp. with the EX 612 kit floating around for $90 with brand new retainers and locks!
Old Oct 24, 2004 | 11:37 PM
  #41
Yeah but those things aren't good for .600 lift in the real world. U have to shim them up WAY to much before they are worth a **** and by that time all the lift potential is gone.
You get what ya pay for.
Bret
Old Oct 24, 2004 | 11:40 PM
  #42
dmoor88's Avatar
well anyone who gets a set of springs good to .600" lift and actually RUNS it to that is nuts to begin with. id use these springs with a lift around .575-.580 at the most.
Old Oct 25, 2004 | 05:00 AM
  #43
Johnnynsac's Avatar
I'm torn between a new clutch or the LE2 package.
Old Oct 25, 2004 | 06:56 AM
  #44
jcolez28's Avatar
How much power difference in the LE 1.5 and the LE 2 package. Thanks.
Old Oct 25, 2004 | 07:30 AM
  #45
hairbear's Avatar
So is there a package for a 396 stroker LT1?
